Adding fields in data shapes at run time from Windchill Object
PreetiGupta
Wondering if there is a way to add a field in data shape dynamically? Example - In Windchill CAD document, if a new IBA is added. Is there a way to get this attribute added to data shape as a field pragmatically? Today  I have to add this new attribute manually into data shape. Same in mashup.
thanks.
4 REPLIES 4
Yes it's, I create DataShape's on demand
Load DataShape:
var dataShapeReference = DataShapes["dataShapeName"];
dataShapeReference.AddFieldDefinition({ name: "newFieldName", type: "FIELD_TYPE", ordinal: 9 });
thanks Carles for replying. Have you used CreateDataShape service in PTC-Windchill-Demo-Thing?
No we don't use Windchill / Windchild extension. But CreateDataShape it's not related to WindChild extension it's a standard TW feature.
yes Carles.
My findings so far on this is - we can get IBA information from CreateDataShape service. The IBAs on WIndchill Object needs to be added manually to the data shape. This is not good. It really takes away configurability.
