HTML with CSS contents will be work inside advanced grid?
For Example:
<!DOCTYPE html>
<html>
<style>
.tooltip {
position: relative;
display: inline-block;
border-bottom: 1px dotted black;
.tooltip .tooltiptext {
visibility: hidden;
width: 120px;
background-color: black;
color: #fff;
text-align: center;
border-radius: 6px;
padding: 5px 0;
/* Position the tooltip */
position: absolute;
z-index: 1;
.tooltip:hover .tooltiptext {
visibility: visible;
</style>
<body style="text-align:center;">
<div class="tooltip">Hover over me
<span class="tooltiptext">Tooltip text</span>
</div>
</body>
</html>
What are HTML and CSS codes will work within Advanced Grid?
Hi @Sathishkumar_C.
Instead of using html, you could instead pass in the url and display the column as a hyperlink.
As an alternative, you could try using the collection widget in table view (in the Properties Panel, View: Table) as opposed to the grid widget.
If you have questions, please let us know.
--Sharon
<a href="http://www.ptc.com" target="_blank">ptc website</a>
'_self' - Open in same window
'_blank' -- Open in new window
'_top' - Open in same window
'_parent'- Open in same window
Can we open in Popup screen from Advanced Grid HTML code?
Article - "Sample CSS for the Grid and Advanced Grid Widgets": https://www.ptc.com/en/support/article/CS314561
Thanks for your information.
But I'm not looking for CSS for advanced grid.
I'm having an CSS and HTML code in Infotable. and trying to render as HTML.
Hi @Sathishkumar_C.
We're not clear on your use case. Can you please provide more details?
--Sharon
I am having an infotable with HTML field. I trying to apply CSS code for cell specific. So i have written HTML code with CSS and trying to render as HTML in advanced grid.
I don't see any changes with respect to CSS. Sample code attached in main thread.
Yes. Above mentioned, we can save as HTML file and it is working.
Hi @Sathishkumar_C.
--Sharon
I conclude that within HTML cell in Advanced Grid, we can not refer that CSS codes. Instead, as @slangley told we can go with collection widget.
