Advanced MQTT messages
SOLVED
Newbie
Hello, I used the tutorial from this site to install the MQTT Extension from the Marketplace to my installation. Everything works fine.
For my purpose I need to transmit additional Information in the MQTT messages such as timestamp, senderID etc. I use JSON Format for the messages. Doing so I cant simply use the MQTT Extension to subscribe to a topic and directly save the messages to the ValueStream or whatever else. I would need a service that is called everytime a new message is received from the subscribed topics and that manages decoding the JSON etc.
Is there a service that is called everytime a message is received? Or how can I create one?
Thanks a lot
Tags (1)
Re: Advanced MQTT messages
The "Not Authorized for Service Invoke" error indicates that the user performing the action does not have the necessary permission to run the service in question.  Easiest way to resolve the problem is to add a run time permission for the user / group that will be running these actions granting Service Execute on the entity in question.  You can do this either as a specific service, or as a overall grant to Service Execute.
On the WeatherStationMQTT thing:
  - Select Permissions > Run Time
  - To grant full Service Execute Permissions, type a group or user name in the topmost box (All properties, events, services), then select the green circle under Service Execute
  - To only grant Service Execute permissions on the service in question, type in the name of the service in the bottom box (Property, Service, Event Overrides), then type in a user or group in the new box that appears for the selected service.
Occasionally you may have to grant permissions to the SuperUser or System user to work around this, though that is usually only in cases where a user context cannot be determined.
16 REPLIES 16
If you have bound your topic to a property, you can use a Subscription to the DataChange event for that property to run services.  (Note, there may be a bug with DataChange events on Infotables; the infotable only triggers the event if a row is added or deleted, so a string would be better)
With the subscription in place, you could then process your request, parse the JSON, etc. each time the topic changes.
Hey Jeremy, thanks for the answer. I tried using a Subscription on the datachange event. I created a property "TemperatureMQTT" which subscribes to the MQTT Topic. I then created a Subscription for the datachange event of this property which should write the processed value via me.UpdatePropertyValues into another property "Temperature" that contains only the number values.
I get the error:
Error processing local event: Execution error in service script [WeatherStationMQTT TemperatureSubscriber.DataChange] : Wrapped com.thingworx.common.exceptions.InvalidRequestException: Not authorized for ServiceInvoke on UpdatePropertyValues in WeatherStationMQTT Cause: Not authorized for ServiceInvoke on UpdatePropertyValues in WeatherStationMQTT
and nothing is written to the other property. Is it somehow not allowed to write to an other property than that the subscription is from? How can this be done?
Hi Nicolas Jourdan​,
Create a Separate (Non MQTT) Thing for the number property and try to update the same.
Ankit Gupta
Take a look at this youtube video, describing exactly what you want to reach:
Minute 7:00 ++
ThingWorx: MQTT Part1 Getting started - YouTube
Thank you this works perfectly
Thanks for the video. This works fine. I also want to use the timestamp from the JSON for my valuestream in case the data transmission is not synchronous. For everyone that wants to achieve the same you can use this JS snippet in the subscription:
var decodedValue = eventData.newValue.value;
var createITParams = { infoTableName : "InfoTable", dataShapeName : "NamedVTQ" };
var properties = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(createITParams);
var row = new Object();
row.name = decodedValue.topic;
row.value = decodedValue.data;
row.time = decodedValue.timestamp;
properties.AddRow(row);
me.UpdatePropertyValues({ values: properties });
Hi Jeremy,
I am trying to accomplish the same task, have gone through the various tutorial to setup my MQTT connection and I have already set my permissions for the thing template and thing. However I still cannot complete the data change subscription event between the property subscribing to the topic and my other created property.
Could this be a configuration issue within Thingworx or could it be the message sent by my gateway? I am able to see the JSON object from the MQTT property.
Any feedback would be appreciated.
Christian Acosta
Hello Christian:
When you say that you aren't able to complete the data change subscription event, is the event itself not firing, or are you getting an error reported as a result of some action that the subscription is taking?  Is the Data Change event keyed off of an MQTT mapped property?
If you have any error messages reported in ApplicationLog, ScriptLog or ErrorLog that might be relevant, it would be useful for troubleshooting this type of problem.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
