The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
We have a tree widget on double click of city we are highlighting that with location pointer image on map. Location is highlighted on double click but image is not being showed.
Problem is, which is not working well for all cities, for some cities it works well for some it is not. We are not doing any manual binding everything comes from DB and bind to tree with proper latitude and longitude.
Below are two cities we are not able see with location image pointer
dusseldorf and duisburg
Hi Anil Kesana,
Did you try to compare the data for one it is working with one which it is not working?
Hi Ankit,
Below is the table of data we are getting from DB. Only Dusseldrof and Barcelona are not working as expected.
