I am using ptcs-grid with multi-row selection enabled.
The first row in my grid is a “Total” (summary) row, added through a service.
I do not want this row to be selectable, and it should also be excluded when “Select All” is used.
Since CSS solutions only hide the checkbox visually (and do not affect selection logic), I would like to know:
What are the supported alternatives or best practices to handle this scenario?
how the Data is looking on grid i am here attaching the screenshot.
from this screenshot i want to Hide the Checkbox for the 1st row whose department="Total"
Depending on your ThingWorx version, you can use the Grid property "AllowDisabledNodes". Check the box then choose a value for "DisabledStateField". This field is a string. Any rows with that string value set to "disabled" will disable the row. I created a quick test and here's a screenshot showing the result when I use Select All. I cannot select the row and Select All does not select the row.
I'm using ThingWorx 9.7.
Hi @SG_14220535,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know.
Abhi
