Am going through tutorials on ptc(part 3) and unable to start vendingmachinesimulator
Guest
When i started wsjavavmstart bat file, vending machine simulator is not getting started. It gives following error: 13:05:35.976 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpo int - Refilling connections on [endpoint 0, uri: ws://127.0.0.1:8080/Thingworx/W S] failed : Connection authentication/registration FAILED
[cause: Application Key not found]] 13:06:36.053 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.CommunicationEndpointM onitorTask - Endpoint reconnection was unsuccessful [name: EP_0, id: 0]
Tags (1)
Re: Am going through tutorials on ptc(part 3) and unable to start vendingmachinesimulator
Nisha, as the error highlights [cause: Application Key not found]] , you need to check if you are providing the Application key and if its correct or not. If you haven't created the application key please do create one associating to one of the user account by navigating to ThingWorx Composer > Security > Application Keys
Thanks Sushant.. it works perfectly now.
Glad it worked out!
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
