Analytics-Manager: Automated notifications
DF_10027356
6-Contributor
Hello all,
I have created a predictive model with a binary goal variable (true/ false). Further I have created a mashup where the predicted results are illustrated. Now I want to implement automated notifications. But the notification should be only send to a person, if a trend in the predictions is recognizable (for example, according to the rule: if a "1" is predicted 20 times in a row, an automatic message should be sent to person X).
I have two questions:
1. Is it possible to create automated notifications? If so, how I can I implement them?
2. Is it possible to create automated notification based on some rules (as I mentioned above)?
Thank you already in advance.
Best regards
David
jgreiner
(To:DF_10027356)
Hi David,
Yes automated notifications can be sent from ThingWorx Platform to user, steps to do so can be found here.  I also believe that you should be able to use the rules you listed above to create the notification.
John
2 REPLIES 2
jgreiner
(To:DF_10027356)
Hi David,
John
DF_10027356
6-Contributor
(To:jgreiner)
Hi John,
I have followed the steps you refered to. But I am not sure how I can send notifications based on a rule like for example: "If the model predicts ten times in a row a "1", send a notification to a specific person".
Do you have an idea how I can realize something like that?
