Hi everyone,
I am about to migrate an application from .NET Framework to .NET Core (Because of EF7 and the fact, that Framework is considered legacy by Microsoft).
Currently the Thingworx .NET SDK requires (and only works with?) .NET Framework, (at least v.4.5.2).
Are there any plans to migrate the SDK to .NET Core?
@DM_9813541,
There has been an update which supports .NET SDK 5.8.4 which supports .NET Frameworx 4.8
There is also the statement on the Microsoft site: ".NET Framework 4.8 is the latest version of .NET Framework and will continue to be distributed with future releases of Windows. As long as it is installed on a supported version of Windows, .NET Framework 4.8 will continue to also be supported."
Hope this helps
