Appkey in Header
SOLVED
Aquamarine
Appkey in Header
It is advised not to pass the appkey in URL. The alternate way is to pass it in header. How to do this? Does passing the appkey in headers is achevied by writing a script? Can somebody show me an example?
Re: Appkey in Header
You could use Postman client to create your REST call and specify App Key in header as below. Once tested successfully, click on code to generate code corresponding to it in the language of your choice.
Hi @Sruthi
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
