Application key
AP_9587236
Application key
What will happen if member of Administrators groups assigned to Application key?
Application Key can be used to log in to the ThingWorx application instead of using standard credentials. If the user that is associated with the application key is a member of Administrators groups, that means the application that is using the application key interacts with Thingworx via Administrator role, it can do anything that Administrator can do.
slangley
(To:AP_9587236)
Hi @AP_9587236.
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
