Appliocation for gps loaction track
krotangan
hii  can i make application using java sdk for thingworx platform
supandey
(To:krotangan)
Hi Khetesh, not sure what sort of application is this planned to be for e.g. if you are simply looking to extend ThingWorx with your custom application you can probably go for the ThingWorx Extension SDK  which is also based on Java . If you are building application for your Edge devices sure you can use ThingWorx EDGE Java SDK for that purpose.
