I'm using Axeda Platform 6.6 and when I tried to add DownloadInstruction to Software Package and create or update the package with V2 API SoftwarePackageBridge I received the error:
An unexpected error has occurred. If you continue to receive this error please contact support and report the event
Some other instruction like RestartAgentInstruction added successfully.
What can be a reason of such behavior?
Best regards,
Vadim Duchovny, Senior Software Engineer
Hello, Vadim:
Now I see what's going on. You are mixing v1 and v2 APIs. DownloadInstruction is a v1 API.
You want to use the v2 DownloadFileInstruction: com.axeda.services.v2.DownloadFileInstruction
You will need to upload the file to the platform first to get a reference. Please see the following link for more information on the process.
-Chris Kaminski
Hello, Vadim:
Can you post the code sample you are using?
6.6 had some unimplemented features, but the bridge features are also very particular in their inputs.
-Chris Kaminski
See attached file (I renamed it from .groovy to .txt)
Before execution I verified that folder "/var/tmp/delivery" has valid file.
Thanks at advance,
Vadim Duchovny
Hello, Vadim:
-Chris Kaminski
Thank you very much, Chris, for excellent assistance.
I'll try to use the example you mentioned.
Best regards,
Vadim Duchovny
Hi, Chris,
I didn't saw at first the second page of your explanation where you give the V1 API script.
I used it and now the package successfully created.
Thank you very much for excellent and absolutely clear assistance
Best regards,
Vadim Duchovny
Hello, Vadim,
I'm glad I could assist.
Would you mind please marking this question as Solved?
-Chris Kaminski
