Hello All,
In the MoC training all the entities that d are created by the user are automatically renamed to "_UserName". Is it a configuration? Does anyboy know how do do it?
Ewerton
Is auto-renaming something you are trying to implement or is there some people with an example somewhere?
Hi Tori,
It is the MoC and I am thinking about using it in the training I provide to make the renaming easier.
Ewerton
Do you have a link to the training? I am still not sure which you are referring to
The course is here: Fundamentals of IoT Development with ThingWorx | Udemy
The platform link is here ThingWorx Login Portal as shown the Pre-Work: Fundamentals of IoT Development with ThingWorx | Udemy
I meant to ask which one of these lectures contains the example, sorry for the confusion
It is here: https://www.udemy.com/thingworx-fundamentals/learn/v4/t/lecture/5346642
Around 1 minute of the lecture.
Hi Ewerton,
Yes we have built an extension into the academic edition of Thingworx that dynamically injects the currently logged in user's user name to the end of any entity they create. If you could message me directly and let me know what your use case is perhaps we can figure out a pathway forward?
Ben
Thanks Ben, will do! Cheers
