Automatic backup procedure while using https
pjoly
11-Garnet
Hello
I followed this link to backup my application : CS210224
In my case thingworx is accessible using https (and not http) and I got this ssl error while executing the backup  procedure from the server (Linux Ubuntu)
[message: Execution error in service script [DailyBackup Event.ScheduledEvent] : Wrapped javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target Cause: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target]
I trie to put  "ignoreSSLErrors: true"  but it doesn't fix the issue.
If I use the same url from remote PC it works fine
supandey
(To:pjoly)
Hi @pjoly I would recommend opening a TS support case for this.
Are you working with Self signed certificate or is it issued by a CA?
supandey
(To:pjoly)
pjoly
11-Garnet
(To:supandey)
Thanks I fixed it with the support
