We have a project with mashup that include auto-refresh, which is working fine when it is run on the machine that has a sign-in on the thingworks server. When we share the link with someone else to test it, it needed to be manually refreshed.
Is there a solution to fix this? Is this something to fix inside thingworks? or does it need to be done on the internet browser using some java command?
Ahmed
Could you share with us export of entities to reproduce?
Maybe it is a visibility or permissions issue.
Raluca Edu
