Hey guys
We have a widget for TW 7.4 called BMCodeHost that I have been trying to get working on V8.4 without success. Is there someone here that has managed to get it working ? There is a github repository with the code, but I am too dumb to build it. Can someone perhaps assist me ?
https://github.com/ptc-iot-sharing/BMCodeHost
You don't need to build it yourself, GitHub has a releases page for repos that typically contains the build results.
The releases page link is in the header above the sources; it has a small tag icon.
In this case, you will find the releases at: https://github.com/ptc-iot-sharing/BMCodeHost/releases.
Don't forget to also update its dependencies.
Hi @apretorius.
Since you're running ThingWorx 8.4, you may want to check out the Git Backup Extension available on the Marketplace. Instructions are available for installing and configuring it.
Regards.
--Sharon
Hi @apretorius.
If the previous response allowed you to find a solution, please mark it as the Accepted Solution for the benefit of others on the community. If you are still working to address the issue as you initially described, please let us know what your specific questions are.
Regards.
--Sharon
Hi @apretorius.
If one of the previous responses allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
