I placed a Bar widget on the mashup, passing the data to the Widget. On Runtime, I can only see the X-Labels for the alternative bar, not all the Bars. Why so?
Thingworx Version: 9.2.1
This was due to a Height/Width Issue of the Chart widget. If I Increase the Height/Width of the bar Chart Widget, then the Tick Labels on the X-axis show up for all the Bars in the Chart.
It's juts the Increase in the Height/Width.
Hello @pshashipreetham
Have you tried setting the "HorizontalAxisMaxHeight" and "HorizontalAxisLabelsRotation" ?
