I'm working on use case,
there are 20 Plants. each plant contains 100+ equipment with each equipment contain 5-6 properties.
now I want to log each property at one minute interval timestamp.
I am logging property by using stream.
shall I create 100+ stream for each equipment 1:1 ratio or 20 stream for 20 plants one stream for one plant.
database is PostgreSQL.
If I query historical data in future it should not affect on performance.
please suggest best way to do this.
Hi @UN_10218888 ,
What you are asking here is usually addressed via an architecture workshop, and usually the answers received in this forum format can help reaching some decisions, but most probably not the best ones.
What we can offer as advice is relatively simple:
Hi @UN_10218888 ,
