I have a datable containing 100 000 rows.
I need to iterate this datatable and do some operation for each row.
Obviously I cannot do that on one service (I will have 100% timeout problem) and I cannot increase the timeout value.
The solution I am thinking of:
1-Take rows slice by slice. (50 rows every time).
2-When the 50 iterations are done , I trigger the next 50 rows (subscription on a property).
3-I finish with I reach the count of all rows in the datatable.
What do you think about this solution ?
Is there a better alternative ?
How to get the 50 rows I need to process since I don't have an id that increment automatically (so I cannot see how to manage the query to get the right 50 rows I need to process)
Thank you for your help
Hi @AliBenBelgacem,
I suggest (if you have the CSV-Parser)
This will atleast reduce the time for 'GetDataTabelEntries' you do on the initial step.
Just a though from top of head
Hi @AliBenBelgacem can you take a look at the below reference, and let us know your output?
https://community.ptc.com/t5/ThingWorx-Developers/Iterate-Datatable/m-p/646167#M42203
Hi @AliBenBelgacem,
If you found either of the responses helpful, please mark the appropriate one as the Accepted Solution for the benefit of others in the community.
Regards.
--Sharon
