Jan 28, 2020 9:39 AM UTC
Iterate Datatable
Hi ,
I have Datatable with some records. I want to get the specific rows or field values by using Timestamp, and later I have to send the result through the mail. how we can get it? can someone has done it?  I am expecting pseudo code in javascript using datatable.
Thank you
Feb 3, 2020 10:57 AM UTC
yes, got it now , major query resolved!! now I am looking for filter data by avoiding time in timestamp. It should work with matching only Date without time. how can we filter timestamp field?
thanks
Jan 28, 2020 10:10 AM UTC
i think you need to create datatable with datashape having one datetime field as primary key.
store data to this datatable using service adddatatableentries.
now fetch the data from this datatable using getdatatableentrybykey ( where key is your timestamp field)
this will return one row in form of infotable. then you use infotable functions primarily for loop to iterate through infotable , get the values and store it in variables.
later you can send those values in email using sendmessage or other services from your mail server thing.
Jan 28, 2020 11:09 AM UTC
Hello rosharma,
first of all thank you for quick response, I have already mahineKey as Primary key and suppose I want to get last week report by using timestamp field of Datatable. how we can do it ? by using query? by using any javascript code?
Thank you
Jan 28, 2020 3:23 PM UTC
i think you can use QueryDatatableEntries on datatable passing in query parameter using "Between" keyword to generate the data specific to users inputs.
query would be like
var query =
 "filters": {
 "type": "Between",
 "fieldName": "Duration",
 "from": "2",
 "to": "12"
And more on query parameter you can refer thingworx help center link
https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Composer/Things/ThingServices/QueryParameterforQueryServices.html
