I have a thing "GLOB" that contains global persistent properties
I have another thing "THG1" that has a property "prop1" that is bound to one of GLOB.
Do I need to set also on THG1 that "prop1" is persistent or is it enough the persistent flag on GLOB ?
From a simple test (by just restarting THG1) seems that it is enought set persistent the prop at GLOB .... but I have a cloud instance and cannot restart the whole app easily ....
I have done same test as you described and the value of THG1 property is kept after Tomcat/server restart.
Best regards,
Raluca Edu
Best regards,
Raluca Edu
