Binding services from datatable
MM_9023322
Hi all,
Is there any disadvantage if we bind the services from datatable directly on mashups?
Thank you!!
Mukul
(To:MM_9023322)
I don't think there is a disadvantage, but it's good to have a wrapper, especially for the services used in data transactions from DB. Moreover, if you have a wrapper service, then you can also handle inputs and outputs according to your need and use case.
Mukul
2 REPLIES 2
Mukul
(To:MM_9023322)
Mukul
MM_9023322
(To:Mukul)
Thank you @Mukul for your response!
