Binding widget according to my expression
fmanniti
Is it possible to bind a widget to a service according to a certain expression?
For exampleI have a boolean:
if myBool = true
bind grid to serviceA
else
bind grid to serviceB
Hi Fabio,
Not this way. But you can:
  • If you want exactly the same grid configuration ( same columns,... ): Have a service which calls ServiceA or ServiceB depending on myBool value as a parameterS
  • If grids should be different: Have two grids, and show/hide one or the other depending on the myBool
Best Regards,
Hi Fabio,
Best Regards,
First solution works fine. Thank you
