Thingworx not getting started
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hello All,
I am using "Thingworx-Platform-H2-Developer-Freemium-7.1.2-b6". After installation of Apache tomcat, i have deployed thingworx. But it is not getting started with the following message
"FAIL - Application at context path /Thingworx could not be started"
localhost.log
SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.listenerStart Error configuring application listener of class com.thingworx.system.ThingWorxBootstrapper
java.lang.UnsupportedClassVersionError: com/thingworx/system/ThingWorxBootstrapper : Unsupported major.minor version 52.0 (unable to load class com.thingworx.system.ThingWorxBootstrapper)
at org.apache.catalina.loader.WebappClassLoaderBase.findClassInternal(WebappClassLoaderBase.java:2544)
at org.apache.catalina.loader.WebappClassLoaderBase.findClass(WebappClassLoaderBase.java:858)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1301)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1166)
at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:518)
at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:499)
at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:118)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4764)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5303)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:940)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1816)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Catalina.log
SEVERE [http-nio-8181-exec-6] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
SEVERE [http-nio-8181-exec-6] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
Any help is much appreciated.
Senthil
- Labels:
Install-Upgrade
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
This error points to your JRE version, Please check if your JRE version is 1.8.*.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Sivaranjan,
Thanks for the response. I am using JRE 1.7. Should I use 1.8 ?
Senthil
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Senthil, click here to access the system requirements documentation for the 7.1 version. As noted in the document 1.8 is required, and the tested version is 1.8.0_92-b14 (64-bit).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Yes please, use JRE 1.8.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thanks a lot. it works.
