Binding widgets to entry in Advanced Grid
tlichtenberger-
Good morning!
I am currently trying to bind other widgets or even mashups to a specific entry in the advanced grid.
Do you know if this is even possible? If so, can I realize this with the normal advanced grid or will I need the advanced tree grid for that task?
If this is not possible, is there a way to extract the current string in the search-box of the grid?
Thank you for in advance for any advice or help you give me
Hi Theresa Lichtenberger​,
Are you looking to bind the selected entry from Advanced Grid to another Widget?
If yes, set the rowSelection property in Advanced Grid widget to single/ multiple as per your requirement.
And bind the Selected Row(s) of the Service to the widget/mashup.
I hope it helps.
I hope it helps.
Hey Ankit Gupta​,
I have already set the rowSelection property to single but I haven't yet understood how to retrieve the data of the selected row.
The property "selectedRows" shows an ingoing arrow which means I cannot get the data this way.
The only outgoing arrow properties the advanced grid has are the DoubleClicked- and Filter-event and the QueryFilter.
So how can I retrieve the data from the selected row?
Thanks for helping me out again
Theresa~
I am referring to the selected Row(s) of the service which is feeding data to Advanced grid widget.
i.e. in the Right hand panel -> your_custom_service -> selected row(s) (just below All data).
hey Ankit Gupta​,
totally missed that! Thanks for your help
