Binding
Ziyad
8-Gravel
Binding
Hello All
I have created services for each LED in order to visualize the data, services work perfectly but LEDS are updated all the time as you can see in the photo below
I added a trigger serviceInvokeCompleted to visualize the updated data but it creates a weird binding each time I try to connect it to my service :
Could you please tell me why that happened, and what can we do to solve this issue
Thank you for your answers
Rocket_Max
(To:Ziyad)
Hello @Ziyad
Please see the added red line, these two services then call each other
BR,
Max
PaiChung
22-Sapphire I
(To:Ziyad)
You've created an infinite loop as you can see from the blue binding coming all the way around back to the front.
Please eliminate that and think of a different way to do your event flow
slangley
(To:Ziyad)
Hi @Ziyad.
If the previous response allowed you to resolve your issue, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for participating in our community.
--Sharon
Rocket_Max
(To:Ziyad)
Hello @Ziyad
BR,
Max
Thank You for your answers the small problem was resolved,
I had services whose entry depended on the output of other services and the events had to be reorganized a little
