Blog Comment Notification
ptc-6292144
3-Visitor
I am wondering if there is a snippet I could use to have an email sent to a user when their blog post gets commented on. I have noticed that I receive an email when a post on the community site gets commented on and wanted to know how I could incorporate that.
Thank you,
Mike
8 REPLIES 8
smanley
(To:ptc-6292144)
Hi Michael,
There is the
SendMessage
service snippet on the MailServer ThingTemplate that you can call from a subscription on your blog.
1.) Create a Notification Thing that implements the MailServer Template and configure your SMTP settings here.
2.) On your Blog Thing, create a service to send messages using the SentMessage Snippet from your Notification Thing in the Entities tab.           Set the message, subject, and email address in the parameters of this service.
3.) On your Blog, add a subscription with
AddComment
as the event trigger and call your send message
Service
from this
Subscription
Saeed
Nevermind Saeed, I was able to figure it out.
Thank you,
Mike
Saeed,
Thank you for the response! For the "from" portion of the SentMessage snippet should I put the name of the Notification Thing or the email address I setup within the Notification Thing?
Thank you,
Mike
adam11
(To:ptc-6292144)
Hi Mike,
You'll put the email address that you are using to send email, not the name of the Thing sending it.
Also,
How do I set the email address to the user's email address who's post was commented on as well as reference what the comment said?
Thank you,
Mike
adam11
(To:ptc-6292144)
Mike,
When an Event is triggered, it sends relevant data to any Thing that subscribes to it. In the case of CommentAdd, you get the id of the Blog entry, the type of entry and the comment's id and the parent's id. With this information, you can retrieve the Blog entry using GetComment() or a similar Service and retrieve the source of the comment's email address by access his emailAddress User Extension.
adam11
(To:adam11)
Mike,
Just wanted to touch base with you and see how you're making out with this functionality. If necessary, I can provide you with a simple example of how to send emails when a new comment is added.
Thanks Adam! I was able to figure it out unfortunately the network I am on will not allow emails sent on port 25. Trying to find a work around to it currently.
