Blog Widget - Add New Post
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Is there a way to have an event trigger when a user clicks the add new post button within the blog widget? I have my blog widget setup in a footer that expands and collapses using the new 5 SP1 feature but when the user clicks the add new post button, the add new post overlay shows up underneath the blog widget when it is expanded. I am trying to have the blog widget collapse when the user clicks the add new post button.
Thank you,
Mike
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Mike,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
For now, yes but also from a UI layering stand point I think it would be beneficial to have the footer containing the blog widget minimize when the user clicks the add new post button and displays the entry panel.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Okay. This will require a modification to the Blog widget to support a Clicked Event for the Add New Post button. Another option is to create your own UI to manipulate the Blog Entity. With this option, you'll be able to use the Clicked Event of the Button widget to collapse the panel. Similarly, you can expand the panel after the entry has been added (ServiceInvokeCompleted) which, in my opinion, would be preferable to keeping it collapsed. Of course, this expanding/collapsing will be happening behind the popup so it is unclear to me how this is beneficial.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Adam,
How can I modify the Blog widget to support a Clicked Event for the Add New Post Button or when viewing a previous post? I have a header in the mashup and the popups are rendering underneath of it due to the bug. It becomes a big issue with viewing a previous post because the close button is located at the top and it is covered up by the header. Is there a way to modify how big the pops are when clicking on a previous post or adding a new post to the blog widget?
Thank you,
Mike
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Mike, I would recommend installing our next release that will fix the issue vs. doing this customization.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Pai,
Will it be a while before the next release comes out?
Thank you,
Mike
