Bug ? JSON array returns {} from data table
seanccc
I have a data table and one of the fields is JSON type .   I can write a JSON object into the table successfully,  but when getting the JSON object back,  the array property of the JSON object becomes {}.
The workaround is that I have to convert the array field into String and then call JSON.parse to get the JSON array back .
Is it a known issue ?
I uploaded a reproducible XML file for the problem , you can run AddJsonValue firstly , then run  GetJson to observe the log  .
ThingWorx 8.4.2 + PostgreSQL 10
Sean
7 REPLIES 7
Hello Sean,
The DataTables work fine, the actual issue is with JSON.stringify, which doesn't traverse complete JSON object. E.g. this code outputs "1" as expected:
logger.debug("The original json array fileDataBatchLines:" + JSON.stringify(fileDataBatchLines[0][0]));
We created a trivial (four lines of code) ThingWorx extension to work around this issue, here it is: https://github.com/vilia-fr/twxdevext
You can use it as following:
var str = Resources["DevelopFunctions"].JsonToString({ json: fileDataBatchLines });
logger.debug("The original json array fileDataBatchLines:" + str);
In the log you can see complete JSON, with "_" standing for line breaks to improve readability.
DISCLAIMER: We don't support this extension officially, use it on your own risk. I bet there's a better, more standard way to do it, I just don't know about it.
/ Constantine
Sorry Sean,
Forget about extension -- I checked, and we've made it only to put linebreaks inside the output. Just skip JSON.stringify altogether and it'll work:
logger.debug("The original json array fileDataBatchLines:" + fileDataBatchLines);
/ Constantine
@Constantine ,
But if I use the original  fileDataBatchLines directly,  it doesn't has the array functions, such as : concat, filter.
Sean
Sean,
ThingWorx wraps arrays into json objects with property « array ». Try fileDataBatchLines.array.filter.
/ Constantine
@Constantine ,
I tried the statement below,  but got error because fileDataBatchLines.array is undefined .
logger.debug("fileDataBatchLines.array:" + fileDataBatchLines.array);
fileDataBatchLines.array.filter(function(item){
    logger.debug("item: " + item);
Hello Sean,
Sorry for the late reply.
AFAIK JavaScript array filter() method was introduced in ECMAScript 5, while ThingWorx supports JavaScript 1.7, which corresponds to ECMAScript 3 with some extensions. Under the hood ThingWorx uses Rhino 1.7r4 as its JavaScript engine. Although support for ECMAScript 5 was introduced in 1.7r3, it is not used by default, so ThingWorx sticks to JavaScript 1.7, which is described in Help and a couple of Tech Support tickets.
Constantine
@Constantine ,
Thank you for the explanation .
If call javaScript array concat() , it also raise function undefined error.  But concat() was introduced in Javascript 1.2.
In a summary:
  • fileDataBatchLines.concat  //undefined
  • fileDataBatchLines.array    //undefined
