Send information via REST API from smartphone
SOLVED
Regular Member
Spoiler
 I have a trial version Thingworx of 3 months installed on my computer. I downloaded and installed Httper APP on my smartphone and I´m trying to send information to thingworx via REST API but I can´t connect to Thingworx and the error message is: "Cannot access to the URL, check your connection and service provider"
I have connected smartphone and computer in the same network.
IP Computer= 192.168.1.22
IP Smartphone= 192.168.1.24
Port= 8080
This is the URL, headers and body:
Request method PUT
URL= http://192.168.1.22:8080/Thingworx/Things/DataLogger/Properties/Temperatura
Headers= AppKey= b2245650-d77e-4f8a-8dbb-4acbabf85230
                 Content-Type => application/json
                 Accept =>application/json
Body= {
             "Temperatura": 34
Do I have something wrong? Could you help me with that?
Thank you in advance
BR
Luis
1 ACCEPTED SOLUTION
Re: Send information via REST API from smartphone
Yes! Before doing REST API you need to ensure that Composer is accessible from your mobile browser.
5 REPLIES 5
Within the mobile browser can you get to Thingworx? Like <Thingworx Server>/Thingworx/Things/Datalogger/Properties
Hi @PaiChung
No, I can´t access within mobile browser.
Then you need to check your computer's firewall settings -- looks like it doesn't allow incoming requests on port 8080.
/ Constantine
I have opened port 8080 in my computer´s firewall settings but it still doesn´t work. Is it possible that my antivirus is blocking my conexion?
Thank you
-Luis
