I found a bug in the Fieldset-Widget. Nested fieldset inherit title of the parent fieldset.
Scenario:
I put three fieldsets inside of a other fieldset. The parent fieldset gets his title from a service. The first child fieldset gets its title from a other service. The second has a static string as title and the last child fieldset has a translated title (via [[translationToken]]).
All fieldset now gets the same title (on runtime) from the parent fieldset. This bugs only occurs if the parent fieldset get the title via binding.
Tested TWX versions:
- ThingWorx 8.5.2-b90
- Thingworx 9.0.0-b9557
Hi @drichter.
This issue is being addressed in ThingWorx 9.1 targeted for release at the end of 2020.
--Sharon
Thank you for reporting this.
I have done a quick test and I can indeed reproduce.
I will report this to R&D and will post the reference here once done.
Thank you
Christophe
For the record, this has been reported to R&D and is now documented at https://www.ptc.com/en/support/article/CS327150
Hi @drichter.
The reported issue has been targeted for fix in the next 9.x release. Once we have further details regarding that release, I will post them here.
--Sharon
Hi @drichter.
--Sharon
Hi @drichter.
ThingWorx 9.1 containing the fix for your issue was released a few weeks ago.
Now that the release is available, please mark the appropriate response to your original post as the Accepted Solution for the benefit of others with the same issue.
--Sharon
