Bugs in .NET SDK regarding ValueStream
jaeeunc
1-Newbie
There's the steamsensor sample in the ThingWorx DotNet SDK 5.5.
I built the sample code and run and made it connected to the ThingWorx Server.
And created SteamSensor1 Thing implementing RemoteThing and did the temperature/pressure properties binded.
And checked 'logged' for those properties and set Valuestream on the SteamSensor1 thing.
But the test result of  'QueryProperyHistory' service has the timestamp of '0001-01-01 09:00:00'.
(So always only one row is returned.)
(In case of running 'QueryNumberPropertyHistory' for 'temperature' , it returns rows with the timestamp '0001-01-01 09:00:00'. )
I tested ThingWorx DotNet SDK 5.5/ 5.0 both and the result were same.
And I found the SteamSensor Example of ThingWorx C SDK works well.
(When the SteamSensor of C SDK connected, the timestamp of Valuestream are fine.)
There must be some bugs in ThingWorx DotNet SDK.
Could someone check this for me?
jaeeun
2 REPLIES 2
Aanjan
9-Granite
(To:jaeeunc)
The SteamSensor example does not generate timestamps as it just calls SetProperty() by default. In order to generate individual timestamps, you would have to use SetPropertyVTQ() instead.
Here is a KCS article which has more information on this (including some sample code to enable timestamps) - https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS206137&lang=en_US
ibanham
1-Newbie
(To:Aanjan)
Note that there's a slight error in the example code in that TS article:
If you follow the example and use vtq.setTime(new DateTime()) that will set the timestamp to January 1, 0001 at 00:00:00.000. You need to use...
vtq.setTime(DateTime.Now); to get the current date and time set against the property update.
