Building Custom Widget Extension
the_incapit
6-Contributor
I would like to build  a card widget extension for Thingworx (version 8.5). I have the CSS and html codes, but how can I implement the functionality or preferably I would like to have some already existing widget extension  which I can customize and build a card extension.
Card Widget will display value with a certain style.
So can anyone suggest any thing I can work on, either on PTC or on GitHub rather than a work around to make the look.Any Custom Card Widget Extension done by anyone would be a great help as I am new to extension development
A Picture of an example card is given below
ThankYou
Then, you will need to follow documentation, different options:
3 REPLIES 3
Why don't you use the collection widget?
Thank You For Your replay
I cant use an existing widgets, It's like I need  a custom extension. Building a Custom extension is  a mandatory for my project. I cant use workarounds or existing widgets.
