Button click inside contained mashup to switch between mashups in contained mashup
TS_9588135
7-Bedrock
Hello all,
What I am trying to build is the following:
I have a main mashup with a banner at the top and a contained mashup underneath.
When this main mashup is loaded, I select a certain mashup to be added in 'name' of contained mashup.
Based on button clicks happening in this contained mashup, I want the contained mashup to switch between
2 different mashups.
Is this possible?
If yes, I will need some help please
My idea is the following:
Have 2 contained mashups on top of each other and make them visible based on button click inside them.
Is this feasible?
suverma
(To:TS_9588135)
Hi @TS_9588135
Can you please check below shared posts which speaks about achieving a similar use-case as you have mentioned:
How to change displayed mashup on button click
Change Contained Mashup on Button Clicked Event
mgoel
(To:suverma)
@TS_9588135 Did you get a chance to check below response on this thread.
If you think this works please mark it accept as solution for the benefit of other community users.
Mohit
