Calendar Widget - timezone 4 hours forward
LP_10027711
i am using the calendar widget https://github.com/ptc-iot-sharing/CalendarWidgetTWX and for some reason the times on the widget are +4 hours to my infotable date times. any advise?
This is my infotable
the widget
i had to change my computer time zone to "automatic", that fixed it
Note for whoever would look in the future at this question: the content available at https://github.com/ptc-iot-sharing  is not PTC supported content, and it is available as is , without any guarantee whatsoever (presales content).
While asking question around that content can be done in this forum, since this forum is not dedicated to custom components not supported by PTC, you will find much more success raising an issue in the Github repository where you got the content from.
