Calling service a specific times throughout the day
Chao123
I am trying to call my service 'ResetSheetCount' on each hour throughout the day. (7,8,9,10,11,12, .etc). I am wondering what is the best route to go with this. To use a timer that calls my service every second (use JS to determine whether the time is correct to reset sheet count) or create 8 or 9 schedulers that will execute the service at the correct times. Any other suggestions would be great.
slangley
23-Emerald II
(To:Chao123)
Hi @Chao123.
From an efficiency standpoint, running the scheduler every hour is the best solution.  Here is a link to the ThingWorx Help Center to provide more information.
--Sharon
9 REPLIES 9
slangley
23-Emerald II
(To:Chao123)
Hi @Chao123.
--Sharon
Chao123
(To:slangley)
This was my thought as well, however that route isn't going to run the service at those specific times.
slangley
23-Emerald II
(To:Chao123)
Hi @Chao123.
Perhaps I'm not fully understanding.  Can you explain why the suggestion will not work?
--Sharon
Chao123
(To:slangley)
Hello again @slangley ,
I need that count to reset at say 7 am exactly and then 8 am exactly. If I use the scheduler at 1 hour intervals this isn't necessarily going to execute those services at 7 am and 8 am. It may be 7:07 or 8:07. At least that is my understanding
slangley
23-Emerald II
(To:slangley)
Hi @Chao123.
Which version of ThingWorx are you running?
--Sharon
Chao123
(To:slangley)
Sharon,
I believe it is 8.3.10-b1010
slangley
23-Emerald II
(To:Chao123)
Hi @Chao123.
The scheduler was changed in 8.5--see article.  For the version, you are running, you may need to create a schedule for each hourly run needed.
--Sharon
Chao123
(To:slangley)
Sharon,
Aha, that is what I had figured..
Thank you for the help!
slangley
23-Emerald II
(To:Chao123)
Hi @Chao123.
If my previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
