Can I "append" two infotables without loop?
fmanniti
If I have two infotables from the same datashape and I want to make a third one given by the two, is it possible to append them in some "smart way" without doing this:
var tableLength = table1.rows.length;
for (var x = 0; x < tableLength; x++){
    var row = table1.rows;
    table3.AddRow(row);
var tableLength = table2.rows.length;
    var row = table2.rows;
    table3.AddRow(row);
result = table3;
ankigupta
(To:fmanniti)
Hi Fabio Manniti​,
I would do it like following:
1. Get the Row Length of both Infotable.
2. Copy the one with more length in table 3 by just assigning it. Will not loop in.
example: Table1 has 1000 Rows and Table2 10000 rows. So I would just do Table3=Table1.
3. Then loop through the other table and copy each item.
And ThingWorx provide Union option to combine two Infotables into one. I suppose you are looking for this.
var params = {
  t1: undefined /* INFOTABLE */,
  t2: undefined /* INFOTABLE */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Union(params);
ankigupta
(To:fmanniti)
Hi Fabio Manniti​,
var params = {
