Hello. I am trying to achieve the following result:
If value is 0, then display "None", otherwise display the value number (so if value is 10, display "10").
I can do it through services, but I was wondering whether I could do it only through a State Definition. Like maybe an expression that evaluates to the Value when it's put into Display Name field?
And making the widget visible/invisible?
No, the widget remains visible. I'd just like to have a Label that displays "None" or a number other than 0, depending on the input.
Arseni, would using a ValueDisplay widget make sense? For the ValueFormat field, you can set state-based formatting for that. For the styles, you can potentially create a style to be displayed when the value is 0, and use one for all others.
Hi Arseni,
You have two options
