I'd like to ask how Complex Event Processing could be achieved in ThingWorx Composer for evaluating value streams. For example timescale based events:
When the lamp is switched to ON/OFF 3 times within 10 seconds - fire an special event / call a special service.
or:
When the motion sensor A was triggered 10 times within the last hour and motion sensor B was triggered 30 % less - call a specific service.
Is that possible out of the box? What would be a best practice to implement rules like this?
Thank you very much,
Markus
Markus, you could look into adding Alerts to that property and/or subscriptions. To start off simply, do you have access to ThingWorx tutorials? I believe there were some exercises around adding alerts to specific properties so that once they reach that value, a subscription would be triggered based on that.
Hi Markus,
I implemented such scenarios with a combination of Alerts and Converge BusinessProcesses (BP) with evaluations in custom, javascript-based services.
The scenario that I implemented was the following:
Here is how the BP looks like:
Here is the signature of the AlertRuleEvaluator.ValidateAlertCountInTimespan() service:
and here is the code I used:
//if alert source is a thing, then do it once, otherwise for all by QueryImplThing/Shape
//for now I impl only per Thing
var result = "false";
logger.info("eventInfo: "+eventInfo.ToJSON());if(eventInfo.eventData){
var alertDetails=eventInfo.eventData.getRow(0);
//specify query based on input param
var startDate, endDate = eventInfo.eventTime;
switch(TimeUnit){
case 'MILLIS': startDate = dateAddMilliseconds( endDate, -1*Timespan); break;
case 'SECONDS': startDate = dateAddSeconds( endDate, -1*Timespan); break;
case 'MINUTES': startDate = dateAddMinutes( endDate, -1*Timespan); break;
case 'HOURS': startDate = dateAddHours( endDate, -1*Timespan); break;
case 'DAYS': startDate = dateAddDays( endDate, -1*Timespan); break;
case 'MONTHS': startDate = dateAddMonths( endDate, -1*Timespan); break;
case 'YEARS': startDate = dateAddYears( endDate, -1*Timespan); break;
default: startDate = dateAddSeconds( endDate, -1*Timespan); break;
logger.info("timespan: from "+startDate+" to "+endDate);
var query = {
"filters": {
"type": "AND",
"filters": [
"fieldName": "name",
"type": "EQ",
"value": alertDetails.name
"fieldName": "sourceProperty",
"type": "EQ",
"value": eventInfo.sourceProperty
"fieldName": "eventName",
"type": "EQ",
"value": eventInfo.eventName
logger.info("query: "+JSON.stringify(query));
var params = {
startDate: startDate /* DATETIME */,
endDate: endDate /* DATETIME */,
query: query /* QUERY */,
};// result: INFOTABLE dataShape: AlertHistory
var foundAlerts = Resources["AlertFunctions"].QueryAlertHistory(params);
logger.info("foundAlerts: "+foundAlerts.ToJSON());
result = ((foundAlerts.rows.length > AlertCountThreshold)).toString();
I hope this gives you an impression how CEP can be implemented with ThingWorx.
Best regards, moritz
Hey Moritz, this seems to be very promising - thank you for this!
However, I think unfortunately I do not have access to the Converge Business Process Editor because I am in the academic program.
Hey Aanjan, I am familiar with subscriptions - what I want to achieve is that the alert only triggers if a number of events occur in a defined time window. Normal alerts simply trigger when a threshold is reached, but I only want to fire an event when this threshold triggered i.e. 3 times within 10 seconds.
Maybe someone has any other ideas how to do this ?
My current solution would be to send relevant values out to a CEP-Engine like Esper or WSO2 an then trigger a service via REST API if a match is found, but it would be nicer to have all the logic in ThingWorx.
Hi, I think about a work-around. I'd create a new Thing which contains a property "counter" and a property "startingTime", or keep the same thing with these two new properties.
The first time the threshold is reached, a first alert increases this "counter" and set the date for "startingTime". The next time the threshold is reached, the alert checks firstly if "startingTime" + 10 seconds < now, then the counter will be incremented by 1 or set "counter" back to 1.
A second alert of "counter" will be triggered if it reach 3 in order to do the "real" action.
