The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I tried to access OPC Aggregator using third party OPC DA client such as Matrikon Explorer and OPCExpert, but not successful. Matrikon Explorer and OPCExpert is the same PC as OPC Aggregator. Error in OPCExpert said that cannot access because no proper license in OPC Aggregator, but as far as I know the OPC Aggregator doesn't need license. So can ThingWorx OPC Aggregator act as OPC DA server? or only can be OPC DA client?
Article - "Connectivity guidelines for ThingWorx OPC Aggregator": https://www.ptc.com/en/support/article/CS321770
Hello @BH_9819031,
It looks like you have a response from a community members. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
