The message you are trying to access is permanently deleted.
i Stored image in Grid but it looks very small as it is inserted as a cell value..i used BaseType of the field is 'Image'.
can we expand image by clicking on it in Grid?
Thanks.
Hi @VS_9760165,
Are you using a legacy Grid widget or a Grid Advanced ? What type of Renderer did you set for your column containing the Image in the "Configure Grid Columns" menu ?
There are a few possibilities I can think of :
I hope this helps !
Hi @VS_9760165,
I hope this helps !
Hi @VS_9760165.
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
