Can localization be used in a Mashup Expression?
Timo697
I often use the Expression function in mashups to display a modified version of a property of a Thing.
For instance:
output = DeviceName + " Description";  //DeviceName is a String Parameter
I am trying to add localization to my mashups and would like to be able to use a token for the " Description" text.  How can I do this?.
abjain
(To:Timo697)
@Timo697 You can try defining a session parameter with a default value as 'Description' and then that variable will be accessible in the mashups in the Session tab where you can bind it to your expression's input parameter.
Timo697
(To:abjain)
What would I set the Base Type as?
I set it to String then wrote a localization token into the Default Value:    [[Test_Description]]
My code in the expression is now:
output = Device + " " + Description;
Now, the expression has an output of:    Device [[Test_Description]]
