I have kept a column in grid as hyperlink through column render. Is it possible to open a popup on click of that particular column hyperlink alone? I dont want to open a popup on click of that row, instead I want to open a popup when i click that hyperlink text row in a column. How can we achieve this using advanced grid?
Thanks in advance,
Shalini V.
@svisveswaraiya : You can try providing links in the columns through a service directly and then bind it to grid advanced. Please import the attached entities on an 8.5 twx and see if this is something required by you.
I do not believe this can be done with a grid or advanced grid. If the content is an actual hyperlink, you can active the hyperlink by clicking on it, but there isn't a 'column' or 'cell' clicked event.
As a more inefficient work around, you could have it as a Collection widget rendering the rows.
Hi @svisveswaraiya.
If one of the previous posts was helpful, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
