Can not login into Composer
drieder
Hello Everyone,
I am not able to login into the Thingworx Composer. After entering the correct username and password the login window disappears and appears again but with blank fields and nothing happens.
I think it is because I disabled the PTC.login.Authenticator (I think its called like that but I am not totally sure), while I had access to the Composer. Apparently I can not login with my credentials with the Authenticator being disabled.
Is there a way to activate this Authenticator e.g. via a Rest Call? Just like it is possible to update property values or execute services I hoped I could enable the Authenticator again.
If anyone knows which call I should make and what the exact name of the Authenticator is, please let me know. I am also open for other approaches to tackle my problem.
I am working with a Trial Version of Thingworx btw. and I do not have Administrator Rights (because I am using the Composer for Thingworx Studio - AR application)
Best Regards,
Dominik
POST
http(s)://<servername>:<port>/Thingworx/Authenticators/PTCAccountsAuthenticator/Services/EnableAuthenticator
Headers
Content-Type: application/json
appKey: <appKey>
and to list all Authenticators:
GET http(s)://<servername>:<port>/Thingworx/Authenticators
Headers
appKey: <appkey>
POST
Headers
appKey: <appKey>
Headers
appKey: <appkey>
posipova
20-Turquoise
(To:drieder)
Try this POST request
    1. http://localhost/Thingworx/Authenticators/ThingworxBasicAuthenticator/Services/EnableAuthenticator?Accept=application%2Fjson-compressed&_twsr=1&Content-Type=application%2Fjson
    2. Request Method:
      POST
    3. Response Headers
      Content-Type:
      application/json;
