Can not run sample Thingworx java sdk code
Regular Member
I am trying to run code provide from https://developer.thingworx.com/en/resources/guides/thingworx-java-sdk-tutorial
put threads are executing repeatedly, no error occures.
I have not provided  Thingworx username and password in my code. I had only set appKey , which i created from Thingworx composer Application key.
After executing i get Logs as shown in file.
6 REPLIES 6
Re: Can not run sample Thingworx java sdk code
Have you checked the connection from the composer/platform side? It seems like it's connecting with no issues. You may look in your application log too to see if there is anything unusual in there (from the monitoring tab in your Composer).
Thank you  posipova,
Yes I looked into the application log , I found their a warning as:
Server WebSocket closed unexpectedly, unregistering from Server Endpoint [ws session id: 8, endpoint id: 9, endpoint name: null] An existing connection was forcibly closed by the remote host
******************Also,
Do I need to provide my Thingworx username and  Password in code or some other file for authentication?
Based on the logs you provided, it actually seems like it's working. Have you checked the connection whether it's set to true? Your sdk log shows pong being received which means it's connected.
Hi @shindemayur.
If the previous post by @posipova helped you to solve your issue, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
Thanks for the reminder @slangley ,
but I am able to find Accept solution option on the page.
Hi @shindemayur.
You are most likely not logged in:
Following login you should see the option to select the appropriate solution.  Just remember to scroll to the appropriate response before clicking the Accept as Solution button:
PostLogin.PNGRegards.
--Sharon
