Can't add row for infotable in runtime
aelgov
I want to create new infotable from datashape, then add rows to it.
I get an error:
JavaException: com.thingworx.common.exceptions.InvalidRequestException: Invalid Reference to Object In Script
This is the code I use:
var params = {
  infoTableName : "InfoTable",
  dataShapeName : "MyInfoTableDataShape"
var myInfoTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
for(var i = 0; i < Logs.length; i++){
var newEntry = new Object();
newEntry.DateTime = logDateTime;
newEntry.Reason  = log.Reason;
myInfoTable.AddRow(newEntry);
var result = myInfoTable;
When I add rows to an infotable property and add - var result = myInfotableProperty it works like a charm.
4 REPLIES 4
jkaczynski
(To:aelgov)
Hi Assaf Elgov​,
You're referring a different variables in your script, such as: Logs, logDateTime, log.Reason. Are you sure each is a valid variable / parameter?
What version of Thingworx do you use? What parameters of what base type you pass to this service?
J.
It is just part of the code not the whole code.
I'm 100 percent sure it is valid, I logged them.
TWX version: 6.6.9
all strings besides 1 which is number
supandey
(To:aelgov)
Assaf, you missing "." for adding DateTime from Logs, shouldn't it be
newEntry.DateTime = log.DateTime;
aelgov
(To:supandey)
Because I use alot log.DateTime I inserted it into var called: logDateTime
