Can't get ThingTemplate.QueryImplementingThingsWithData(...) to work with Query filter
rtaylor-3
Greetings,
I'm trying to query for implementing things on a template which have certain property values.
I'm doing this in Java.
Here is an example:
ThingTemplate template = // get thing template
String property1Value = "someValue";
String property2Value = "anotherValue";
JSONArray a = new JSONArray();
  a.push(newFilterJSONObject("EQ", "property1", property1Value));
  a.push(newFilterJSONObject("EQ", "property2", property2Value));
  JSONObject filters = new JSONObject();
  filters.put("type", "AND");
  filters.put("filters", a);
InfoTable results = template.QueryImplementingThingsWithData(500.00, null, null, filters);
This will return all implementing things as if it is ignoring the filter.
I've reviewed the Query docs and am using the composite query example:
var query = {
filters: {
type: "And",
filters: [{
type: "GT",
fieldName: "Duration",
value: "12"
type: "TaggedWith",
fieldName: "tags",
tags: "MaintenanceIssues:PowerOutage"
This is the resulting JSON from the Java JSONObject above:
"filters":[
  1. {},
    • "fieldName":"property1",
    • "type":"EQ",
    • "value":"1"
  2. {}
    • "fieldName":"property2",
    • "type":"EQ",
    • "value":"1"
"type":"AND"
There are no matches in my data so i should be getting back an empty InfoTable, but i'm not.
What am i doing wrong?
qn
(To:rtaylor-3)
You need another "filters" outside:
     filters:
          "filters":
               {"fieldName":"property1","type":"EQ","value":"1"},
               {"fieldName":"property2","type":"EQ","value":"1"}
          "type":"AND"
7 REPLIES 7
qn
(To:rtaylor-3)
The resulting JSON is not "normal", the 2 filters are outside of the {}. Or is it just a problem of copy-paste ?
Have a look on this discussion How to populate query when testing the QueryStreamEntriesWithData service?​.
a badly formatted query is ignored and you get all the results
rtaylor-3
(To:qn)
Sorry....copy-n-paste error, below is the generated output:
"filters":[
"type":"AND"
And it did review that discussion before posting.
qn
(To:rtaylor-3)
Could you try "type":"And" instead of "type":"AND"​, just in case of syntax.
rtaylor-3
(To:qn)
No go....still ignoring the filter and pulling back all records.
qn
(To:rtaylor-3)
     filters:
          "filters":
          "type":"AND"
rtaylor-3
(To:qn)
Boom! That did it. I should have seen that....just glossed over it. Another set of eyes is always good. Thanks so much!
qn
(To:rtaylor-3)
You're welcome!
