Can't launch trial server.
juhent
3-Newcomer
Hey
I have a PTC hosted 30day Thingworx trial server and I'm having trouble launching it. I have logged in on developer.thingworx.com and started the instance:
When clicking launch I cannot reach the composer:
I also can't reach the server from Kepserver Thingworx native interface:
This has happened a couple times now on multiple PCs and browsers; and just waiting for PTC to shut down the instance due to inactivity time and then restarting has helped before, but now I can't seem to get to the instance even after multiple shutdown-launch-cycles.
Thank you.
jebeck
(To:juhent)
We restarted your server and it is accessible.  It sounds like there may be a pattern of connectivity issues with this server.  Please reach out to the Developer Portal team directly (TWX-DevZoneHelp@ptc.com) if you have any issues.
10 REPLIES 10
jebeck
(To:juhent)
I'm having the same issue. Replying to this post cuz I didnt want to start a duplicate topic.
Can you plz help?
Your server has been restarted and is accessible now.
I'm having the same problem
Best Regards
Gonçalo Machado
hi @Gmachado14 & @Sybren
We have reached out to the team supporting the Trials and they have reset your respective instances.  Please let us know if you continue to have further issues.
Leigh
Thanks, it's solved !
jdorcey
3-Newcomer
(To:jebeck)
I am having the same issue with my server: https://PP-1807271610FL.devportal.ptc.io/Thingworx
Could you please help me with this?
Thank you!
cnuga
11-Garnet
(To:jdorcey)
I am having the same issue with my server https://PP-1808241816MN.devportal.ptc.io/Thingworx
Please resolve it quickly.
I'm also having this issue. Thanks in advance!
vikasdwankhede
(To:juhent)
Hi, I have exactly same issue with trial version from last 2 days, I have already left my 2 days with trial due to this issue. please help me as quickly as possible.
Regards
Vikas
