Can't see OpenStreetMap widget after installing the extension
olatz
I have a Thingworx 8.5.2 platform installed. I am trying to use OpenStreetMap Widget but, after installing the extension I can't see it in the Widget list of the mashup. During the installation, I didn't get any error or warning message.
Attached OpenStreetMap version detail and widgets list detail.
Thanks in advance.
Olatz.
slangley
(To:olatz)
Hi @olatz.
Are you referring to the widget that used to be available on the Marketplace?  If so, it's not likely that it is compatible with ThingWorx 8.5.2.  Since support is not available for this widget, we are unable to confirm.
You should be able to use the widget as a starting point for creating your own.  Please refer to these resources for assistance:
Create a Mashup Widget Extension
Best Practices for Packaging and Deploying ThingWorx Applications
Regards.
--Sharon
7 REPLIES 7
slangley
(To:olatz)
Hi @olatz.
Regards.
--Sharon
slangley
(To:slangley)
Hi @olatz.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
olatz
(To:slangley)
Hi Sharon,
If the OpenStreetMap widget is not ready for use on platform 8.5.2, which map widget could I use? I only can find a google widget, it is the only one that works nowadays on version 8.5.2?
Thanks.
Olatz.
slangley
(To:olatz)
Hi @olatz.
We may have some new widgets on the Markeplace in the future, but details are not currently available.
If you are unable to write your own widget, you can reach out to our Sales team for engaging with our Services group.  They may be able to provide the assistance you need for writing an extension with the functionality needed.
Regards.
--Sharon
slangley
(To:slangley)
Hi @olatz.
Unfortunately, the widget provided is no longer supported.  Please reach out to our Sales team for engaging with our Services group.  They may be able to provide the assistance you need for writing an extension with the required functionality.
Regards.
--Sharon
Yes, the Google Maps widget works with 8.5 but Google now requires a developer key to display maps
An updated version of the OpenStreetMap widget can be downloaded here:
https://community.ptc.com/t5/ThingWorx-Developers/OpenStreetMap-extension-error-in-Thingworx-8-5/m-p/635197/highlight/true#M40433
olatz
(To:Rick-Stanley)
Hi Rick,
That's the widget I am using and doesn't work on platform 8.5.2.
Regards.
Olatz
