How to store data from Thingworx to customized excel ? but not in normal csv format.
Hi @jaganprasanth.
There is nothing native to the product for generating .xls files. You could write your own extension for doing so, however. Please refer to these links if assistance is needed:
Packaging and Deploying Applications Built on the ThingWorx Platform
Regards.
--Sharon
Hi @jaganprasanth.
Regards.
--Sharon
There is an extension in the marketplace "DataExporterExtension" which provides 3 formats to download your data in MS Excel,MS Word and PDF. You could give it a try.
Hi @jaganprasanth & @TanmeyTWX.
The Data Exporter extension is no longer available on the Marketplace. You will need to create your own extension.
Regards.
--Sharon
Oh is it? I used that extension long time back.
Thanks Sharon for the update.
Hi @jaganprasanth.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
